Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
The rear panel is secured by 10 screws. Using  a  #00 Phillips Screwdriver,  remove the ten 1.2 mm screws. The screwdriver should be inserted at the same angle as the screws.
  • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
  • The screwdriver should be inserted at the same angle as the screws.
  • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
Hier Übersetzung einfügen
