Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
After you have removed the battery cover, flip the device around to view the motors Loosen and use a JIS #1 screwdriver to remove the two 10mm Screws holding the clear case of the motors Next, gently push the clip (on both sides) with a screwdriver to release the clear case
  • After you have removed the battery cover, flip the device around to view the motors
  • Loosen and use a JIS #1 screwdriver to remove the two 10mm Screws holding the clear case of the motors
  • Next, gently push the clip (on both sides) with a screwdriver to release the clear case
  • To remove the motors, simply pull on it with slight force
Hier Übersetzung einfügen
