Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Using a screwdriver with a J000 Phillips bit, remove the fourteen 3.175 mm screws. Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot. Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens; set the back panel off to the side.
  • Using a screwdriver with a J000 Phillips bit, remove the fourteen 3.175 mm screws.
  • Using a plastic opening tool, pry part of the panel up starting from the sides of the battery slot.
  • Use plastic tweezers to release the rest of the panel from plastic bits holding it in place and pry the panel up around the sides surrounding the fingerprint sensor and camera lens; set the back panel off to the side.
Hier Übersetzung einfügen
