Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
  • Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
  • When removing this connector, it is helpful to use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
Löse den Stecker des Kabels zum Thermosensor des optischen Laufwerks, indem du ihn in Richtung Oberkante des iMac ziehst.
Es ist dabei hilfreich, wenn du beide Nasen auf den Seiten des Steckers mit den Daumennägeln in Richtung Oberkante des iMacs drückst.
-[* black] Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
-[* icon_note] When removing this connector, it is helpful use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
+[* red] Disconnect the optical drive thermal sensor connector from the logic board by pulling its connector toward the top of your iMac.
+[* icon_note] When removing this connector, it is helpful to use your thumbnails to push the ears on either side of the connector toward the top of your iMac.
