Zum Hauptinhalt wechseln
Disassembling Pentax K200D Front Cover
Was du brauchst
  1. Disassembling Pentax K200D Front Cover, Preparation: Schritt 1, Bild 1 von 1
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: Schritt 2, Bild 1 von 1
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: Schritt 3, Bild 1 von 1
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: Schritt 4, Bild 1 von 1
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.539 Anleitungen geschrieben
Ein Kommentar
How do l clean the prisum…
brett_lorking - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 43
Insgesamt: 6,363
