Einleitung
跟随本指南的步骤更换您的Samsung Galaxy S7的后盖玻璃。
移除后盖玻璃之后,你将需要更换粘合剂,并把新的后盖重新组装到手机上。
Was du brauchst
按相反的步骤组装设备。
按相反的步骤组装设备。
31 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
4 Kommentare
They don’t tell you this, but be careful with the picks when you are trying to separate the back cover from the chassis. It’s very easy for the pick to get between the backplate, which is really clear plastic, and the foil-ish lining that makes it look like sleek black glass- I’m sure the heat doesn’t help keep the foil laminated to the backplate. Then your only option will be to replace the entire backplate, or remove the foil-ish lining and let the back of your phone be au natural.
When I removed the back cover, I found the adhesive had stayed adhered to the phone and separated from the back cover. This actually made it easier to remove cleanly with the forceps.
Should you not replace the adhesive tape? If so, what type/brand/size should one use? Would this be appropriate? 4mm 3M red Strong Sticky Glue Tape for Samsung (https://www.amazon.com/gp/product/B07P1J...) ?
Hi Bryan!
You should definitely replace the adhesive. You can use some custom-cut adhesive made specifically for the S7, or you can use double-sided tape like Tesa tape. For this situation, the precut card would be more than enough.
