Einleitung
要确保处理器不发烫且运行顺畅,涂散热膏是必须的。按照该通用指南的操作方法,您可以在移除散热器或CPU后重新涂抹散热膏。想要获得针对你所使用的CPU的进一步的指导,请查阅如下Arctic Silver网站的文章:涂抹方法.
Was du brauchst
用一张咖啡滤纸或无纺布沾取一点异丙醇(又名IPA,90%以上浓度),来将残留在与散热片接触表面上的散热膏清理干净。
当该表面干净后,使用一张新的咖啡滤纸或无纺布沾取更多的异丙醇,来擦除表面的油质并将表面准备好。
请勿直接接触芯片或散热片,或者让任何灰尘或碎屑落在表面。 即使指纹也可能阻碍芯片的热传递。
让散热器完全晾干。
同样的,使用咖啡滤纸或无纺布沾取一点异丙醇或ArctiClean散热膏清除剂,将处理器表面残留的散热膏擦除。
使用一张新的咖啡滤纸或无纺布,沾取一些异丙醇,来擦去表面上任何油质并使表面准备好。
将处理器完全晾干。
根据您的处理器型号来选择涂抹散热硅脂的方法——水平涂抹,竖直涂抹,中点涂抹或散开涂抹。
如果您使用散开涂抹的方式:
用一块塑料(如塑料袋或一次性手套)包裹食指的尖端。
在处理器中心上点少量的散热膏。
使用手指轻轻涂抹整个处理器核心上的散热膏。
处理器现在处理好,可以安装散热片了。
若想重新组装您的设备,请按照相反的拆卸步骤操作。
1034 weitere Nutzer:innen haben diese Anleitung absolviert.
90%
Beginne zu übersetzen ›
36 Kommentare
For heat sinks with a spring on the screws: Wonder why there are springs on the heat sink screws? Do not over tighten them, the springs are there to help you apply the correct amount of pressure on to the CPU and GPU. If you tighten them all the way, it may not be the correct pressure! Leave maybe 1 mm of space, just before the screw stops turning. iFixit forgot to mention this important part, and also in the heat paste guide!!
This is completely untrue. The holes bored in the heat sinks are in fact a larger diameter than both the threads and the shoulder of the heat sink screws. The screws should be fully tightened (as they were from the factory) to maintain correct pressure against the processors.
I have two green lights on my xbox slim ... Should I do all of this to get rid of them? I'm not sure if they are supposed to be green. I bought my wii and remotes from a refurbishing place. I don't have the red ring of death, but I think it is from over heating.
OMG Hi -
Thank you so much for this! Have been struggling for months with CPU diode sensor reporting 262F/128C and CPU dropping to 0.8 Ghz due to Speedstep. Loosened the screws a little and the sensor is back to normal. I cannot thank you enough for this!
