Zum Hauptinhalt wechseln
Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock
Was du brauchst
  1. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Remove Enclosure: Schritt 1, Bild 1 von 1
    • Remove the enclosure by sliding the latch to the right and lifting the enclosure up.
  2. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Remove screws on retainer plate: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    T5 Torx Screwdriver
    $9.99
    Kaufen
    • Using a T5 screwdriver, remove the six screws retaining the latch on the inside of the enclosure and lift out the retainer plate.
  3. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Replace latch with modified version: Schritt 3, Bild 1 von 1
    • Remove the original latch, install the replacement latch with Kensington lock hole, and restore the retainer plate and six screws.
  4. Mac Pro Late 2013 Enclosure Latch Replacement for Cable Lock, Install Cable Lock: Schritt 4, Bild 1 von 1
    • Return the enclosure and slide the latch back to the left. Install cable lock into the exposed hole.
Abschluss
This guide will help you secure your Mac Pro (2013) with any cable lock.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kemper Barkhurst
149 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 2,574
