Einleitung
如果您的尼克松手表需要换电池了,那么这篇指南将教您如何进行更换,并且它只适合于尼克松手表。更换电池不需要特别专业的知识,只需要一盏明亮的灯和一块平整的地方来摆放细小的螺丝。
Was du brauchst
您已经顺利的完成了腕表电池的更换。
如果你发现秒针没有开始走动,一般可能有2个原因。一个可能是在第11到12步调整时间之后,没有正确的放置表冠。还有一种可能是你换了一块坏的电池,如果是这样的话,你需要重复所有的步骤,重新更换一块新的电池。
如果问题依旧,请联系厂家作进一步的处理。
您已经顺利的完成了腕表电池的更换。
20 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
周成波 hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
12 Kommentare
Works for also for my traser h3. Thank you!
Good guide but one does not need to force out battery with a screwdriver. This is overkill. I would not recommend putting a screwdriver there because the gears are exposed in that area and a slip would damage them. Just a finger nail is needed to move a little spring cover slightly to let battery out. Same goes for putting battery back in. Fingers are all that are needed at that point.
I have a "Newton" model Nixon. All black and the watch hands are floating circles just to clarify. It seems to have a battery cover, almost like a strip, holding it in place. Is there a tutorial for this extra step?
Hey Anthony! were you able to find an answer to your question? I’m also looking to replace my Newton’s battery.
Yash K -
That is for the backlight module. It takes a 2016 battery. The battery seen in this tutorial powers the movement and sits underneath the backlight module.
