Zum Hauptinhalt wechseln
怎样处理更换屏幕后iPhone屏幕出现竖条纹
Was du brauchst
  1. 怎样处理更换屏幕后iPhone屏幕出现竖条纹, 静电放电: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Mat
    $24.99
    Kaufen
  2. 怎样处理更换屏幕后iPhone屏幕出现竖条纹, 查看排线接口: Schritt 2, Bild 1 von 3 怎样处理更换屏幕后iPhone屏幕出现竖条纹, 查看排线接口: Schritt 2, Bild 2 von 3 怎样处理更换屏幕后iPhone屏幕出现竖条纹, 查看排线接口: Schritt 2, Bild 3 von 3
    • 检查电缆和主板上的显示器连接处。 污垢,灰尘或碎屑都可能会导致连接错误,应使用软刷和高浓度异丙醇(至少90%)清洁。 检查连接器并根据需要进行清洁。
    • 异丙醇是对皮肤温和但是眼睛刺激物。 使用异丙醇时使用手套和眼睛保护装置。
  3. 怎样处理更换屏幕后iPhone屏幕出现竖条纹, 显示芯片损坏: Schritt 3, Bild 1 von 1
    • 显示屏的芯片有可能被损坏。 特别检查左上角和右上角。 任何损坏迹象都表明该部件有缺陷,需要更换新部件。
Abschluss
屏幕很脆弱的(这肯定是意大利语)。:)
128 weitere Nutzer:innen haben diese Anleitung absolviert.
en zh
100%
Hier starten ›
Matt Zieminski
33.283 Reputation
13 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.718 Anleitungen geschrieben
9 Kommentare
i had a same problem so can someone sent me the video so that video will help me a lot thanks
Suman Biswa - Antwort
i have 4he same problem, mines worse, soon as i turn it on verticle lines its bad you cannot see any thing only lines.. brand new screen with lcd, its not working!!! any solutions? im thinking of o new logic board…
jubonygill - Antwort
I had the same problem when removing and installing an iPhone 6 plus battery. After connecting all four flex cables to the mother board the phone either would not boot up or there were vertical lines on the display. Basics, basics, basics……unplug battery connector. Unplug all four flex cable connectors. Re-attach all four flex cable connectors, then connect battery flex cable. After installing both metal shields and closing the phone it booted up properly and worked just like new. Viola!
bassinbill42 - Antwort
Did you have any problems after doing that to your phone? Or does it still have the lines?
sscorpion34 -
How to fix the vertical lines camera on iPhone 6
Renz Mendi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 50
Letzte 7 Tage: 257
Letzte 30 Tage: 1,258
Insgesamt: 454,383
