Einleitung
学习如何更换你的iPhone 6的屏幕。
这一组件包括前置摄像头,听筒和安装好的液晶保护板,所以安装还是比较简单的.
你只需要拆除旧屏幕然后把home按钮换到新屏幕上就行了.
你也可以使用本指南更换
Was du brauchst
Einführungsvideo
如果你的屏幕玻璃碎了,可以使用胶带粘住整个屏幕,防止玻璃碎屑伤到你。
使用胶带粘满整个iPhone屏幕,直到覆盖整个显示屏。
如果破碎的玻璃在接下来的几个步骤中使吸盘很难粘住,请尝试使用强力胶带(例如布基胶带,然后用其提起显示屏。
将蓝色的手柄朝铰链的方向拉,以解除反向钳的分离模式。
将支撑臂滑过 iPhone 的左边缘或右边缘。
将两个吸盘放到Home键上方的屏幕——一个在前,一个在后(屏幕朝向自己的地方为前)。
将上方吸盘向下压以施加吸力到目标位置。
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
卸下电池排线固定架上的两颗十字型螺丝。
一个2.2毫米螺丝
一个3.2毫米螺丝
In diesem Schritt verwendetes Werkzeug:iOpener$19.99
轻柔地将位于顶端左侧的home键抬升起来,使之从前面板脱离。
In diesem Schritt verwendetes Werkzeug:iOpener$12.99
使用撬棒较细一头轻轻将HOME键撬起,注意屏幕与HOME键之间的粘合剂。
要重新组装你的设备,请按照逆序执行这些步骤。
2428 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
185 Kommentare
Its a good advice to remove the battery power before mounting the flex-cables.
There is power on the second logic-board (even if the phone is turned off) connector from top, misplacing it while assembly can cause short circuit.
Will the short circuit damage the logic board or the camera / earpiece assembly? I'm worried just encountered this very issue even though the phone was off. FF camera and earpiece not functioning.
Battery assembly is one of the important procedures working with manual is the best way to repair an iphone 6 screen
Good advice two: When removing the LCD back shield plate have in mind that the home button connector attached to the shield plate is Very fragile. Its adhered to the screen. Use very little force and do not heat the adhesive too much because then it become even More fragile.
I use ifixits metal spudger without heat but one small mistake and it can be teared.
I have now changed two of these on my phone from different suppliers and both haven't worked!
Could it be that both have been defective products or am I doing something wrong!?!?
Kieran -
