Einleitung
本指南将指导你如何清理你的EarPods。
Was du brauchst
务必等待10分钟使你的EarPods晾干。
85 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Z.Heng hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
31 Kommentare
Best way is clean the larger part with a earbud. The smaller doesnt make that much sound. Blow air onto the larger part after cleaning.
I use a cotton swab (q-tip). First a dry one, then I blow into all openings, next I use a damp (not dripping) q-tip (alcohol, saliva) to remove remaining wax, dirt. There are four opening on each earbud. I clean them all.
With saliva? You &&^&^$ disgusting.
GROSS Saliva? yuck
what the &&^& is wrong with you
