Zum Hauptinhalt wechseln
Removing factory feet from a Mac Laptop (Non-Retina)
Was du brauchst
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: Schritt 1, Bild 1 von 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: Schritt 1, Bild 2 von 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: Schritt 2, Bild 1 von 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: Schritt 2, Bild 2 von 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: Schritt 2, Bild 3 von 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: Schritt 3, Bild 1 von 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: Schritt 3, Bild 2 von 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    iFixit Opening Picks (Set of 6)
    Kaufen
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: Schritt 4, Bild 1 von 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: Schritt 4, Bild 2 von 2
    Adhesive Cleanup Kit (Set of 12)
    Kaufen
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Ziellinie
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Nick
88.851 Reputation
49 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.528 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 51
Insgesamt: 4,359
