Zum Hauptinhalt wechseln
01 | XY Frame Assembly
Was du brauchst
  1. 01 | XY Frame Assembly, 01 | XY Frame Assembly: Schritt 1, Bild 1 von 3 01 | XY Frame Assembly, 01 | XY Frame Assembly: Schritt 1, Bild 2 von 3 01 | XY Frame Assembly, 01 | XY Frame Assembly: Schritt 1, Bild 3 von 3
    • M8 x 40 screw for each corner. Insert T Nuts before M8 screws and do not tighten them now. Just to keep the frame in shape.
    • Blind L metal brackets for Z axis assembly should be inserted before M8 screws as well.
    • There are M8 holes for Z axis assembly on the 320mm aluminium extrusions which should be at the back of the XY Frame. Larger hole should be faced to bottom.
    • Insert two T-nuts for every corner in order to fasten the L brackets on the next step.
    • Do not forget to insert T Nuts for Y motor holder in back and LCD mount in front.
    Frag FixBot
  2. 01 | XY Frame Assembly: Schritt 2, Bild 1 von 3 01 | XY Frame Assembly: Schritt 2, Bild 2 von 3 01 | XY Frame Assembly: Schritt 2, Bild 3 von 3
    • One Metal L Brackets for each corner.
    • Two M6x12 socket cap screws for each metal L brackets.
    • Please align the extrusions on a flat surface like glass or marble and then tighten the M8 screws on the corners and the inside L brackets.
    • T-Nut insert for each bottom corner.
    • Printed Zaribo L brackets.
    • Misumi rubber foot for each corner.
    • M6x20 socket cap screw.
    • Misumi 3030 aluminium extrusion edge cover.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 53
Insgesamt: 3,323
