Was du brauchst
M8 x 40 screw for each corner. Insert T Nuts before M8 screws and do not tighten them now. Just to keep the frame in shape.
Blind L metal brackets for Z axis assembly should be inserted before M8 screws as well.
Insert two T-nuts for every corner in order to fasten the L brackets on the next step.
Do not forget to insert T Nuts for Y motor holder in back and LCD mount in front.
One Metal L Brackets for each corner.
Two M6x12 socket cap screws for each metal L brackets.
T-Nut insert for each bottom corner.
Printed Zaribo L brackets.
Misumi rubber foot for each corner.
M6x20 socket cap screw.
Misumi 3030 aluminium extrusion edge cover.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
