Zum Hauptinhalt wechseln
1 - Kettle - The different functions
  1. 1 - Kettle - The different functions, What are the functions of a kettle?: Schritt 1, Bild 1 von 2 1 - Kettle - The different functions, What are the functions of a kettle?: Schritt 1, Bild 2 von 2
    • The kettle is a kitchen utensil used to bring a liquid to a boil. Electric kettles, which are the subject of this study, have a built-in heater.
    • The most common models are the cordless kettles: the kettles are placed on a base (see photo) connected to an electrical outlet, during the heating phase. The container can then be detached from the base and used as an ordinary container.
    • The operation of the electric kettle is based on the Joule effect. The kettles are equipped with a heating resistor in the form of a ring-shaped tube. The current, when it passes through the resistor, causes an increase in the thermal energy of the ring: the water is heated by heat transfer.
    • To learn more about the Joule effect, visit this site. See also the definition of a "kettle" on Wikipedia
  2. 1 - Kettle - The different functions, Description: Schritt 2, Bild 1 von 3 1 - Kettle - The different functions, Description: Schritt 2, Bild 2 von 3 1 - Kettle - The different functions, Description: Schritt 2, Bild 3 von 3
    • Our study is of the Moulinex brand model AC10-10S011. It is 1100W.
    • The device consists of a base 1 and a container 2. The base is equipped with a power cord. It is equipped with a device 3 which ensures the electrical continuity with the heating resistor which is in the container. This device is secured to avoid any contact with the electrical conductors.
    • In the tank is a heating element 4. A switch allows to start and stop the heating. This kettle is also equipped with an automatic stop when the water has reached the right temperature.
Abschluss
We now know what a kettle is and what its different functions are. We can move on to the study of its operation in the following guide: "a kettle, how does it work?"“Kettles, how do they work?”
7 weitere Personen haben diese Anleitung absolviert.
fr en
100%
shingle hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Atelier Soudé
3.691 Reputation
15 Anleitungen geschrieben
Atelier Soudé Mitglied von Atelier Soudé
Local Repair Groups
5 Mitglieder
30 Anleitungen geschrieben
Ein Kommentar
Hi evry bary 'i m for algeria and i want working whith you so if you ar iteressed send me a messaga message please
Belmokdad Idir - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 55
Insgesamt: 4,429
