Was du brauchst
Einführungsvideo
2 X axis member
2 Y axis member
4 L bracket (Printed or Laser cut)
4 Rubber feet
4 M8 x 40mm socket screws
8 M6 x 12mm socket screws
4 M6 x 20mm socket screws
12 T-slot nuts
Make sure the sockets for the screws are aligned and in the same side.
Using the M8 x 40 screws, join the X and Y members
Tighten just enough to keep the frame assemble together.
Locate the bottom of the frame, where the socket for the head of the screw is drilled.
On the L bracket place
2 M6 x 12mm screws
1 M6 x 20mm screw
Align on the extrusion and tighten the screws
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
