Zum Hauptinhalt wechseln
12-String Takamine G Series Guitar String Replacement
Was du brauchst
  1. 12-String Takamine G Series Guitar String Replacement, Guitar String: Schritt 1, Bild 1 von 3 12-String Takamine G Series Guitar String Replacement, Guitar String: Schritt 1, Bild 2 von 3 12-String Takamine G Series Guitar String Replacement, Guitar String: Schritt 1, Bild 3 von 3
    • Turn the tuning peg corresponding to the string you want to change clockwise until the string is completely loose.
    • This is only if the string is damaged but not completely broken (if the string is completely broken skip to step 2).
  2. 12-String Takamine G Series Guitar String Replacement: Schritt 2, Bild 1 von 2 12-String Takamine G Series Guitar String Replacement: Schritt 2, Bild 2 von 2
    • Use wire cutters to take out the pins located on the bridge of the guitar and completely release the string from the guitar.
  3. 12-String Takamine G Series Guitar String Replacement: Schritt 3, Bild 1 von 2 12-String Takamine G Series Guitar String Replacement: Schritt 3, Bild 2 von 2
    • Place the new string into the hole in the bridge where the pin was taken out.
  4. 12-String Takamine G Series Guitar String Replacement: Schritt 4, Bild 1 von 3 12-String Takamine G Series Guitar String Replacement: Schritt 4, Bild 2 von 3 12-String Takamine G Series Guitar String Replacement: Schritt 4, Bild 3 von 3
    • Place the pin back into the hole to secure the string.
  5. 12-String Takamine G Series Guitar String Replacement: Schritt 5, Bild 1 von 1
    • Grab the string and put it through the hole located on the tuning post of the guitar.
  6. 12-String Takamine G Series Guitar String Replacement: Schritt 6, Bild 1 von 3 12-String Takamine G Series Guitar String Replacement: Schritt 6, Bild 2 von 3 12-String Takamine G Series Guitar String Replacement: Schritt 6, Bild 3 von 3
    • Take the string and wrap it around and underneath itself.
    • Pull the string taught.
    • Twist the string over itself and than cut off the excess string.
  7. 12-String Takamine G Series Guitar String Replacement: Schritt 7, Bild 1 von 2 12-String Takamine G Series Guitar String Replacement: Schritt 7, Bild 2 von 2
    • Turn the tuning peg counterclockwise to tighten the string.
Abschluss
Rey Navarro
145 Reputation
1 Anleitung geschrieben
University of Arizona, Team 6-34, Cools Stephens Fall 2023 Mitglied von University of Arizona, Team 6-34, Cools Stephens Fall 2023
ARIZONA-COOLS STEPHENS-F23S6G34
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 60
