1. Firstly Disconnect  battery Always take the negative terminal off first.
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Unlatch the 2 clasps. Loosen screw on metal band.
    • Unlatch the 2 clasps.
    • Loosen screw on metal band.
  3. Disconnect electronic sensor. Press on the 2 latches, pulling the cable away from sensor.
    • Disconnect electronic sensor.
    • Press on the 2 latches, pulling the cable away from sensor.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Disconnect hose from MAFS. Remove MAFS.
    • Disconnect hose from MAFS.
    • Remove MAFS.
  6. Steps 4-6 are for cleaning only.
    • Steps 4-6 are for cleaning only.
    • Spray MAFS cleaner along direction of travel, shown by arrow.
  7. Clean electronic coupling with electronics cleaner. Clean electronic coupling with electronics cleaner.
    • Clean electronic coupling with electronics cleaner.
  8. Inject conducting lubricant into  MAFS electronic coupling. Inject conducting lubricant into  MAFS electronic coupling.
    • Inject conducting lubricant into MAFS electronic coupling.
  9. Re attach MAFS to air filter housing and intake hose. Tighten screw on metal band. Latch clasps on either side of MAFS.
    • Re attach MAFS to air filter housing and intake hose.
    • Tighten screw on metal band.
    • Latch clasps on either side of MAFS.
  10. Re attach electronic cable to MAFS.
    • Re attach electronic cable to MAFS.
Abschluss
Isaac Nitschke
61 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-28, Regan Fall 2010 Mitglied von Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Mitglieder
9 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 8,073
