Was du brauchst
Firstly Disconnect battery
Always take the negative terminal off first.
'''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Unlatch the two clasps, as outlined in the image.
Loosen the screw on the metal band, using a flathead screwdriver.
Disconnect the electronic sensor from the MAF.
Press on the 2 latches, pulling the cable away from the sensor.
Disconnect the rubber hose from the MAF.
Remove the MAF from the air filter housing.
Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
(Mass Air Flow sensor Cleaner)
Reattach the MAF to the air filter housing and the intake hose.
Tighten the screw on the metal band.
Latch the clasps on either side of the MAF.
