Einleitung
Removing the brake caliper from the rotor is a necessary step for many repairs and modifications.
Was du brauchst
Use a 15 mm box end wrench to remove the two bolts on the back of the brake caliper.
Lift the brake caliper off the rotor and set it aside.
Place the caliper on some type of support so that you do not put too much strain on the brake hose.
Fast fertig!
Abschluss
