Was du brauchst
Lift the bottom of the shift boot to expose the shifting socket.
Use snap ring pliers to remove the circlip securing the shifter to its socket.
Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever.
Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
Remove the shift lever by pulling it straight up.
Remove the plastic bushing in the bottom of the shifter socket.
Remove the 6 nuts and bolts securing the drive shaft to the guibo and the back side of the transmission.
Remove the 4 bolts securing the drive shaft support.
Slowly lower the drive shaft and separate it from the transmission.
Remove the guibo and metal separator plate.
Remove the bolts securing the transmission to the engine and to the starter.
Generally, a jack is recommended for this.
Remove the four bolts securing the transmission support to the chassis.
Lower the transmission out of the car.
In many instances, the transmission may not come free from the engine once the bolts are removed. If this is the case, a pry bar is recommended to help separate the two.
Eine weitere Person hat diese Anleitung absolviert.
