Zum Hauptinhalt wechseln
1986-1993 Volvo 240 Spark Plug Wires Replacement
Was du brauchst
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: Schritt 1, Bild 1 von 1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: Schritt 2, Bild 1 von 2 1986-1993 Volvo 240 Spark Plug Wires Replacement: Schritt 2, Bild 2 von 2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
Abschluss
Install your new spark plug wires in the same manner that you removed the old ones.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
David Hodson
150.503 Reputation
127 Anleitungen geschrieben
2 Kommentare
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - Antwort
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 4,019
