Zum Hauptinhalt wechseln
1986 Fender Stratocaster String Replacement
Was du brauchst
  1. 1986 Fender Stratocaster String Replacement, String: Schritt 1, Bild 1 von 2 1986 Fender Stratocaster String Replacement, String: Schritt 1, Bild 2 von 2
    • Detune the strings completely.
    • No tension on the strings will ensure there is no "snapping" effect that could harm the user during removal.
  2. 1986 Fender Stratocaster String Replacement: Schritt 2, Bild 1 von 3 1986 Fender Stratocaster String Replacement: Schritt 2, Bild 2 von 3 1986 Fender Stratocaster String Replacement: Schritt 2, Bild 3 von 3
    • Remove the strings from the tuners.
    • This can be done in multiple ways, but the method pictured is to straighten out the string and pull the whole string back through the tuner. Strings can be cut and removed in multiple pieces as well.
  3. 1986 Fender Stratocaster String Replacement: Schritt 3, Bild 1 von 3 1986 Fender Stratocaster String Replacement: Schritt 3, Bild 2 von 3 1986 Fender Stratocaster String Replacement: Schritt 3, Bild 3 von 3
    • Insert each of the new strings from the back side of the guitar through the bridge.
    • The thickest string will go in the hole furthest away from the user, if the guitar is sitting on your lap just like the pictures. From there, the second thickest string will go into the second furthest hole from the user and so on. The hole for the strings are BEHIND the visible holes in the first picture.
    • This step that may require a Phillips screwdriver if the backplate covering the bridge is on the guitar.
  4. 1986 Fender Stratocaster String Replacement: Schritt 4, Bild 1 von 1
    • Individually pull the strings to the tuners and insert into the correct tuner.
    • Turn the tuners enough to tighten the strings but DO NOT FULLY TUNE.
    • Fully tuning the strings too quickly after install can lead to the strings snapping, which can lead to injury.
    • The thickest string or top string will go into the tuner closest to the neck of the guitar, and the thinnest string or bottom string will go into the furthest tuner, and the second thickest string will go into the second closest tuner and so on.
    • Make sure each string is slotted into the nut. The "nut" is the white piece at the end of the guitar neck, and it ensures there is zero unintentional vibration in the strings.
  5. 1986 Fender Stratocaster String Replacement: Schritt 5, Bild 1 von 2 1986 Fender Stratocaster String Replacement: Schritt 5, Bild 2 von 2
    • Cut the excess string from the tuners using wire cutters.
  6. 1986 Fender Stratocaster String Replacement: Schritt 6, Bild 1 von 2 1986 Fender Stratocaster String Replacement: Schritt 6, Bild 2 von 2
    • SLOWLY start to tune the guitar starting from the thickest string and going to the thinnest string.
    • Make sure to take your time while tuning. You just went through the effort of replacing your strings, and you don't want them to break!
    • Standard tuning is Open E, and the notes for each string in order from thickest to thinnest is "E A D G B E." A memory trick for this is "Eddie Ate Dynamite, Good Bye Eddie."
  7. 1986 Fender Stratocaster String Replacement: Schritt 7, Bild 1 von 1
    • To prolong the life of your guitar and strings, consider detuning the instrument before extended periods of storage. This will ensure that the strings will not become overly loose, and ensure that the neck of the guitar will stay straight. "Bowing" of the neck is caused by strings being under tension for too long.
Abschluss
Now your new strings should be functioning correctly, and be tuned to the most common guitar tuning. It is possible the strings will fall out of tune faster than before, and this is because new strings tend to stretch out for the first couple of times you use them. This issue will resolve itself over time. As mentioned in the guide, consider detuning your instrument if the it will be unused for long periods of time. This will extend the life of your strings and your guitar.
Andrew Kroll
145 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 113
