Zum Hauptinhalt wechseln
1990-1993 Honda Accord EX Engine Air Filter Replacement
Was du brauchst
  1. 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 3 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 2 von 3 1990-1993 Honda Accord EX Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 3 von 3
    • Flip the switch underneath the steering wheel to open the hood.
  2. 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 2, Bild 1 von 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 2, Bild 2 von 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 2, Bild 3 von 3
    • Open the hood, and keep it in place using the prop rod.
  3. 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 3, Bild 1 von 2 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 1.3 cm Phillips screws from the cover of the case.
  4. 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 4, Bild 1 von 2 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 4, Bild 2 von 2
    • Remove the cover of the casing.
  5. 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 5, Bild 1 von 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 5, Bild 2 von 3 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 5, Bild 3 von 3
    • Remove the old air filter and replace it with a brand-new one.
    • Place the new air filter in the same position as the old one otherwise, you will not be able to screw the cover back on.
  6. 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 6, Bild 1 von 2 1990-1993 Honda Accord EX Engine Air Filter Replacement: Schritt 6, Bild 2 von 2
    • Place the cover back on the casing and screw it back in place.
    • Do not tighten the screws too hard or you risk the chance of breaking the screws.
Abschluss
Oscar Sanchez
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 8-9, Ribeiro Fall 2023 Mitglied von CSU Los Angeles, Team 8-9, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S8G9
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 100
