Einleitung
This guide will assist you in replacing your side mirror if it is broken or shakes.
Was du brauchst
Unscrew the two T25 Screws located on the sides of the mirror.
Inside the door panel, there are two Philips screws. One in the panel's upper right side, the other inside the door pull. Remove both.
Turn the crank handle until the knob is facing upward. Using a hook pick or a small flathead screwdriver, gently pry open the front cover.
Rotating the cover out of your way, unscrew the T20 screw from inside the handle.
Three plastic retaining clips are located at the bottom of the panel. To remove those clips, either use a fastener removal tool or your hands.
Release the door panel from the door lock by lifting it up. To clear the door handle, move the door panel to the right.
With the panel removed. Locate the 10 mm bolt near the speaker at the top. Using a 10 mm socket, loosen the bolt.
To remove the mirror, lift up and to the left to clear the arm inside the door.
