Zum Hauptinhalt wechseln
1994-2004 Ford Mustang Headlight Replacement
Was du brauchst
  1. 1994-2004 Ford Mustang Headlight Replacement, Headlights: Schritt 1, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement, Headlights: Schritt 1, Bild 2 von 2
    • To open the hood, pull the release lever by your foot break inside the car.
    Frag FixBot
  2. 1994-2004 Ford Mustang Headlight Replacement: Schritt 2, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 2, Bild 2 von 2
    • To raise the hood, lift up on handle at the front of the hood.
    Frag FixBot
  3. 1994-2004 Ford Mustang Headlight Replacement: Schritt 3, Bild 1 von 1
    • Pull on the edges until the cover pops off revealing the nut shown in the next step.
    Frag FixBot
  4. 1994-2004 Ford Mustang Headlight Replacement: Schritt 4, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 4, Bild 2 von 2
    • Using the 11mm wrench, remove the nut.
    Frag FixBot
  5. 1994-2004 Ford Mustang Headlight Replacement: Schritt 5, Bild 1 von 1
    • Gently pull out the side paneling using your hands.
    Frag FixBot
  6. 1994-2004 Ford Mustang Headlight Replacement: Schritt 6, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 6, Bild 2 von 2
    • Take out the turn signal light by twisting it. Remove the side panel.
    Frag FixBot
  7. 1994-2004 Ford Mustang Headlight Replacement: Schritt 7, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 7, Bild 2 von 2
    • Remove the bulb from the connector by pulling the two apart.
    • Connect the new bulb to the connector.
    Frag FixBot
  8. 1994-2004 Ford Mustang Headlight Replacement: Schritt 8, Bild 1 von 1
    • In the same area where you removed the screw, remove the clip by hand or use needle nose pliers.
    Frag FixBot
  9. 1994-2004 Ford Mustang Headlight Replacement: Schritt 9, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 9, Bild 2 von 2
    • Identify the three retainers. Two of them are on the same side from which the metal clip was removed. The third is on the opposite side, shown in the next step.
    • Slide the 12mm wrench over the retainer and push until you are able to remove the headlight.
    Frag FixBot
  10. 1994-2004 Ford Mustang Headlight Replacement: Schritt 10, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 10, Bild 2 von 2
    • This is the third retainer.
    • To push the retainers in so that I was able to remove the headlight, I pressed the handle of the wrench against the metal part of the retainers and pushed.
    Frag FixBot
  11. 1994-2004 Ford Mustang Headlight Replacement: Schritt 11, Bild 1 von 2 1994-2004 Ford Mustang Headlight Replacement: Schritt 11, Bild 2 von 2
    • Similar to removing the turn signal, twist the headlight connector and remove the headlight from the bulb.
    • Disconnect the bulb from the connector by pulling the two apart and connect the new bulb. Attach the new bulb to the connector.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
I am looking for a set of RHD headlights for my 1994 Mustang Cobra.
outlbw - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 80
Insgesamt: 2,808
