Zum Hauptinhalt wechseln
1994-1999 Subaru Legacy window bushing replacement
Was du brauchst
  1. 1994-1999 Subaru Legacy window bushing replacement, 3D print bushing: Schritt 1, Bild 1 von 2 1994-1999 Subaru Legacy window bushing replacement, 3D print bushing: Schritt 1, Bild 2 von 2
  2. 1994-1999 Subaru Legacy window bushing replacement, Remove Door Panel: Schritt 2, Bild 1 von 1
  3. 1994-1999 Subaru Legacy window bushing replacement, Remove Lower Rail from Window Regulator: Schritt 3, Bild 1 von 1
    • Lower the window to 90% down.
    • Remove the two nuts connecting the rail to the window regulator. These nuts can be accessed through the hole in the door.
    • Once the nuts are off, remove the rail.
  4. 1994-1999 Subaru Legacy window bushing replacement, Bend Rail to Accomodate Bushings: Schritt 4, Bild 1 von 2 1994-1999 Subaru Legacy window bushing replacement, Bend Rail to Accomodate Bushings: Schritt 4, Bild 2 von 2
    • There is a tab bent into the rail on the rear-facing side to keep the bushings from sliding out.
    • Use the small crescent wrench to bend the edge of the rail until I could slide the bushings in and out.
  5. 1994-1999 Subaru Legacy window bushing replacement, Install Bushings on the Regulator: Schritt 5, Bild 1 von 3 1994-1999 Subaru Legacy window bushing replacement, Install Bushings on the Regulator: Schritt 5, Bild 2 von 3 1994-1999 Subaru Legacy window bushing replacement, Install Bushings on the Regulator: Schritt 5, Bild 3 von 3
    • Lower the regulator mechanism all the way.
    • Use channel locks to force the new bushings onto the window regulator.
  6. 1994-1999 Subaru Legacy window bushing replacement: Schritt 6, Bild 1 von 1
    • Move the regulator up a bit to get enough clearance.
    • Slide the rail onto the new bushings.
    • Lower the regulator all the way down.
    • Use the small crescent wrench inside the door to bend the metal tab back up once the rail is in place on the regulator.
    • Adjust the window regulator back to 90% down.
    • Line up the window bolts up with the holes in your freshly repaired regulator.
    • Reinstall the nuts securely.
    • Grease the rail where the bushings make contact.
Ziellinie
Natalie Thoreson
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 20
