Zum Hauptinhalt wechseln
1994 Jeep Cherokee XJ ECM Replacement
Was du brauchst
  1. 1994 Jeep Cherokee XJ ECM Replacement, ECM: Schritt 1, Bild 1 von 2 1994 Jeep Cherokee XJ ECM Replacement, ECM: Schritt 1, Bild 2 von 2
    • Pull the hood latch towards you to release the hood.
  2. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 2, Bild 1 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 2, Bild 2 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 2, Bild 3 von 3
    • Relieve the pressure on the hood by pushing upward.
    • Using your other hand, slide the hook to the right so it releases from the latch on the frame.
    • Use the hood strut to hold the hood open.
  3. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 3, Bild 1 von 2 1994 Jeep Cherokee XJ ECM Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the connections from battery terminals, starting with negative, circled in blue, then positive, circled in red.
  4. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 4, Bild 1 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 4, Bild 2 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 4, Bild 3 von 3
    • Remove the air filter in the first picture to have access to your ECM.
    • The air filter can be disconnected from the throttle body. The second picture shows where to loosen the gasket connected to the throttle body.
    • The third picture shows an 8mm socket being used to loosen the gasket connected to the throttle body. Remove the air filter connection and place in a safe spot.
  5. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 5, Bild 1 von 2 1994 Jeep Cherokee XJ ECM Replacement: Schritt 5, Bild 2 von 2
    • Loosen the bolt that tightens the gasket to the air intake
  6. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 6, Bild 1 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 6, Bild 2 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 6, Bild 3 von 3
    • The three bolts that were lubricated with WD-40 will need to be removed. (Marked with red circles)
    • The best angle to access the bolts will be from the driver/front tire side. (8mm socket)
  7. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 7, Bild 1 von 2 1994 Jeep Cherokee XJ ECM Replacement: Schritt 7, Bild 2 von 2
    • Remove all three bolts with an 8mm socket and place the bolts in a safe place.
  8. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 8, Bild 1 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 8, Bild 2 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 8, Bild 3 von 3
    • Remove the bolt from the wire harness using an 8mm socket so that the ECM is now free to replace.
  9. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 9, Bild 1 von 2 1994 Jeep Cherokee XJ ECM Replacement: Schritt 9, Bild 2 von 2
    • Do not attempt to remove the clips from the wiring harness. This will expose the wires and might damage them.
  10. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 10, Bild 1 von 1
    • Swap the ECM.
  11. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 11, Bild 1 von 1
    • Plug in the wiring harness to the ECM and tighten the bolt using an 8mm socket.
  12. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 12, Bild 1 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 12, Bild 2 von 3 1994 Jeep Cherokee XJ ECM Replacement: Schritt 12, Bild 3 von 3
    • Screw in all bolts to the frame of the vehicle.
    • Tighten the bolts till they are snug. Do not overtighten. The bolts will strip the frame and the frame is not replaceable.
  13. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 13, Bild 1 von 1
    • Place the air filter gasket back on the throttle body and tighten the bolt until snug. (8mm socket)
  14. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 14, Bild 1 von 1
    • Place cables back on terminals.
    • Make sure to place the positive terminal first (red circle) then the negative terminal (blue circle)
  15. 1994 Jeep Cherokee XJ ECM Replacement: Schritt 15, Bild 1 von 1
    • Wait 10 minutes after reconnecting the battery to the cables. After 10 minutes, turn the key to the ignition.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 42
Insgesamt: 465
