Zum Hauptinhalt wechseln
1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement
Was du brauchst
  1. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement, Front and rear wiper blades: Schritt 1, Bild 1 von 1
    • Get your wipers in the service position by lifting the wiper arm up until it stands on its own.
  2. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 2, Bild 1 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 2, Bild 2 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 2, Bild 3 von 3
    • Unlatch the cover on the old wiper blade from the arm.
  3. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 3, Bild 1 von 2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 3, Bild 2 von 2
    • Firmly grasp the wiper blade and pull the wiper blade towards the car.
    • Turn the wiper blade 90 degrees so that it is perpendicular to the wiper arm.
    • Note: Use a 'J' motion to unhook the wiper blade from the wiper arm.
    • Pull the wiper blade away from the wiper arm.
  4. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 4, Bild 1 von 2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 4, Bild 2 von 2
    • Rest the wiper arm on a towel.
    • Putting the wiper arm down removes the risk of it falling over and placing the wiper arm on a towel removes the risk of scratching the windshield.
  5. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 5, Bild 1 von 2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 5, Bild 2 von 2
    • Prepare the new wiper blade.
    • Note: There are several different types of adapters. The 4runner uses a J-hook adapter.
    • Refer to the instruction manual from the new wiper blade to ensure you have the correct adaptor attached.
  6. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 6, Bild 1 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 6, Bild 2 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 6, Bild 3 von 3
    • Lift the wiper arm from the down position back into the service position.
    • Insert the wiper arm perpendicular to the wiper blade in the hole.
    • Insert the J-hook into the wiper blade.
    • Note: When inserting, make a 'J' type motion.
    • Turn the wiper blade so that it is parallel to the wiper arm.
    • Firmly grasp the wiper blade and shift it away from the wiper arm until you hear an audible click that confirms that it is secured.
  7. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 7, Bild 1 von 1
    • Close the latch on the new wiper blade.
  8. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 8, Bild 1 von 2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 8, Bild 2 von 2
    • Remove the towel from the windshield and lower the wiper arm back down.
  9. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 9, Bild 1 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 9, Bild 2 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 9, Bild 3 von 3
    • Repeat the previous eight steps for the second wiper blade.
  10. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 10, Bild 1 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 10, Bild 2 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 10, Bild 3 von 3
    • Remove the two Phillips screws from the rear wiper assembly.
    • The screws will be reused for this part.
    • Place a towel underneath the wiper arm.
  11. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 11, Bild 1 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 11, Bild 2 von 3 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 11, Bild 3 von 3
    • Place the old wiper fixture onto the new wiper blade.
  12. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 12, Bild 1 von 2 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 12, Bild 2 von 2
    • Screw in the rear wiper assembly hand-tight.
    • Do not fully tighten the screws.
  13. 1995-2002 Toyota 4Runner Front and Rear Wiper Blades Replacement: Schritt 13, Bild 1 von 1
    • Align the rear wiper assembly and tighten the screws once it is aligned.
Abschluss
Replacing your wiper blades following the steps outlined in this guide is a simple yet crucial maintenance task to ensure optimal performance and safety on the road. By regularly inspecting and replacing worn-out blades, you can maintain clear visibility and confidence in various weather conditions, ultimately enhancing your driving safety.
Eine weitere Person hat diese Anleitung absolviert.
OptimusPrime
217 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-7, Morris Spring 2024 Mitglied von UC Davis, Team 2-7, Morris Spring 2024
UCD-MORRIS-S24S2G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 107
