Einleitung
Whether your bulb is burned out or require an upgrade, learn how to replace the bulb in your 1996-2000 model year Honda Civic
Was du brauchst
Pop the hood via hood release latch by driver's side.
Reach for the latch under the hood and prop the hood up on the prop rod.
Remove the screw/10mm(depending on year) bolt holding the bumper on. This will be located in the front wheel well on the passenger and driver side.
Repeat this step for the other side of the vehicle and pull the bumper down carefully.
Remove the two bolts visible on the top of the headlight.
Remove the hidden screw facing towards the grille towards the bottom of the headlight.
Remove the other hidden bolt on the wheel well side of the headlight, same area as in step 3.
Remove the connector on top of the rubber boot by squeezing the clip and carefully wiggling loose.
Test your new headlight bulbs and make sure they function properly. If they do not work at first, try cleaning off the connection mating your new bulb and its connector.
To reassemble your components, follow these instructions in reverse order.
