Einleitung
If you own an older vehicle you know that the factory light bulbs usually aren’t very bright. In this guide I will be showing you how to replace the tired old factory lights with brand new LED replacements that will help you see your dash better and give a new look to an old car. This guide is specific for a 2001 Jeep Wrangler TJ.
Was du brauchst
First a look at the original lights in the dash.
Remove the two screws that hold the second part of the dash cluster, then remove the dash cluster.
Now that all four screws holding the dash on are visible, remove them to allow the dash to come off.
Assemble the new lights by pushing the butt end of the bulb down into the body until seated fully.
Remove the old light bulbs from the dash and replace them with the new ones. To do so simply twist the body of the light and it will pop right out. To install the new bulbs do the opposite. Push the body of the bulb flush with the mounting surface on the dash and then twist to hold it tight.
3 weitere Personen haben diese Anleitung absolviert.
