Zum Hauptinhalt wechseln
1997-2004 Ford F-150 Air Filter Replacement
Was du brauchst
  1. 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: Schritt 1, Bild 1 von 3 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: Schritt 1, Bild 2 von 3 1997-2004 Ford F-150 Air Filter Replacement, Air FIlter: Schritt 1, Bild 3 von 3
    • Pull on the hood release handle located on the driver's side to the left of the brake pedal to pop the hood.
    • To open the hood, reach into the gap at the front of the truck and feel for the latch.
    • Push it to the left to release it and lift up on the hood.
  2. 1997-2004 Ford F-150 Air Filter Replacement: Schritt 2, Bild 1 von 3 1997-2004 Ford F-150 Air Filter Replacement: Schritt 2, Bild 2 von 3 1997-2004 Ford F-150 Air Filter Replacement: Schritt 2, Bild 3 von 3
    • The air filter box is located in the front right front corner of the engine bay.
    • To disconnect the Mass Airflow Sensor squeeze the tab on the connector and pull it away from the sensor.
  3. 1997-2004 Ford F-150 Air Filter Replacement: Schritt 3, Bild 1 von 3 1997-2004 Ford F-150 Air Filter Replacement: Schritt 3, Bild 2 von 3 1997-2004 Ford F-150 Air Filter Replacement: Schritt 3, Bild 3 von 3
    • Use a flathead screwdriver or a nut driver to loosen the hose clamp that attaches the air filter box to the air inlet tube.
    • When the clamp is loosened set the air inlet tube to the side.
  4. 1997-2004 Ford F-150 Air Filter Replacement: Schritt 4, Bild 1 von 3 1997-2004 Ford F-150 Air Filter Replacement: Schritt 4, Bild 2 von 3 1997-2004 Ford F-150 Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the air filter box clamp by pulling the clamp handle towards you.
    • This will loosen the clamp and allow the air box to separate.
  5. 1997-2004 Ford F-150 Air Filter Replacement: Schritt 5, Bild 1 von 2 1997-2004 Ford F-150 Air Filter Replacement: Schritt 5, Bild 2 von 2
    • To separate air filter box rotate it while pulling the left side of box upwards, removing it from the housing.
    • Once the left side of box is removed reach into the right side of the box and remove the air filter.
    • Dispose of the old air filter and replace with it with the new air filter.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 59
Insgesamt: 830
