Einleitung
Replace or clean (if applicable) the air filter every 12,000 miles to keep your vehicle running smoothly.
Was du brauchst
The air filter housing is located on the driver side of the car.
Loosen the four housing screws on the plastic air intake box.
Loosen the hose-clamp on the air intake tube located on the side of the air intake box.
Remove the air intake tube from the intake box.
Remove the air filter from the housing and inspect it.
If it can not be cleaned, then it should be replaced with a new one.
4 weitere Personen haben diese Anleitung absolviert.
