Einleitung
Replacing burnt out or broken bulbs is a quick and easy fix that makes your car easier to see from behind, helping to prevent accidents.
Was du brauchst
Locate the plastic casing that holds the trunk liner in place, directly behind the tail light.
Unscrew the plastic casings.
Unclip the rear panel of the tail light assembly. There are two clips on the top and two on the bottom.
Remove the rear panel from the rest of the assembly.
After putting the new bulbs in, turn the desired lights on to check that the newly installed bulbs work correctly.
4 weitere Personen haben diese Anleitung absolviert.
