Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Werkzeuge
Keine Werkzeuge angegeben.
Ersatzteile
  1. Prop up your hood.
    • Prop up your hood.
    • Make sure you prop your hood up with your hood prop rod.
  2. Locate the back of the headlight you plan to replace the bulb in.
    • Locate the back of the headlight you plan to replace the bulb in.
    • This will be directly behind the headlight assembly.
    • If you are replacing your left headlight, you may need to remove the battery to have enough room to do this replacement.
  3. Disconnect the headlight.
    • Disconnect the headlight.
  4. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  5. Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
    • Remove the rubber cover by pulling on the tab marked "Pull Top" away from you.
  6. Release the bulb by pushing the metal fastener inward and then moving it upwards. Release the bulb by pushing the metal fastener inward and then moving it upwards.
    • Release the bulb by pushing the metal fastener inward and then moving it upwards.
  7. Remove the bulb.
    • Remove the bulb.
  8. Insert the new bulb. Make sure the metal tabs fit correctly.
    • Insert the new bulb. Make sure the metal tabs fit correctly.
    • I've read that touching the glass on the bulb can shorten the life of the bulb, so try not to do that.
Abschluss
To finish your headlight bulb replacement, follow these instructions in reverse order.
16 weitere Nutzer haben diese Anleitung absolviert.
Chris Opperwall
1.274 Reputation
1 Anleitung geschrieben
The 2000 and 2001 Camry models take 9006 (HB4) bulbs for the low beams and 9005 (HB3) bulbs for the high beams, rather than the 9003 (HB2) linked here -- at least for the North American models I've looked up.
If you have the original owner's manual that came with the car, there's a table of all the bulb types you'll need for different lights in the "Do-It-Yourself Maintenance" section. It doesn't hurt to double check.
rakslice - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 11
Letzten 7 Tage: 47
Letzten 30 Tage: 239
Insgesamt: 41,877
