Zum Hauptinhalt wechseln
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Stop the car engine.
    • Stop the car engine.
    • Indentify the car battery.
  2. Identify the screw on the right side of the battery which maintains the battery.
    • Identify the screw on the right side of the battery which maintains the battery.
  3. WIth the 8mm box end wrench, remove the black (ground) cable.
    • WIth the 8mm box end wrench, remove the black (ground) cable.
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. WIth the 13mm wrench, remove the red cable.
    • WIth the 13mm wrench, remove the red cable.
  6. Unscrew the bottom screw  identify in step 2 with the 13mm socket wrench.
    • Unscrew the bottom screw identify in step 2 with the 13mm socket wrench.
    • Remove the old battery.
  7. Insert your new battery and lock the it with the screw.
    • Insert your new battery and lock the it with the screw.
    • Grease the battery contacts.
  8. Put back the red cable and then the black one.
    • Put back the red cable and then the black one.
    • Start your car.
Ziellinie
10 weitere Nutzer haben diese Anleitung absolviert.
sissssou
439 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 8
Letzte 7 Tage: 61
Letzte 30 Tage: 318
Insgesamt: 36,206
