Einleitung
As a car ages some of the connections can deteriorate. If your LCD display is not working properly with only some of the segments showing, or if the segments sometimes show and sometimes does not show, then it’s likely the result of a faulty connection. In some cases, the repair is relatively easy. Sometimes, the connection between the LCD and the circuit boards simply needs to be cleaned. In this case though, there is no connection that can be cleaned so the connection needs to be re-soldered. If you need more information on soldering check out the guide on iFixit.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use the spudger to remove both side covers to access the radio removal holes.
Remove each side of the radio separately. Starting with the left side, put the 'radio removal tool' in the bottom 4 holes until you hear a "click"
Then pull the left side of the radio out.
Pull the radio out, you may have to wiggle it back-and-forth several times to get it out.
Remove the radio Antenna.
Remove the wiring harness by pressing on the clip on the underside of the harness.
Using the Phillips #2 screwdriver, remove the two 5.0 mm screws on either side of the control panel.
Using a Phillips #2 screwdriver, screw in both 5 mm screws on either side of the radio.
Ein weiterer Nutzer hat diese Anleitung absolviert.
