Einleitung
Use this guide to replace your 4-cylinder Honda Accord's distributor cap. This specific guide was created for a non-VTEC F23A5 engine, but other 4-cylinder Honda engines will be similar enough to follow the same basic steps
Was du brauchst
Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
Disconnect the four spark plug wires from the distributor cap by pulling their connectors straight away from the sockets on the distributor cap.
Use a 1/4" drive, 8 mm deep socket to remove the three hex bolts securing the distributor cap to the engine.
Use a dental pick or a small screwdriver to gently remove the D-shaped o-ring around the distributor cap flange.
Install a new o-ring in the seal recess, making sure that it is sitting flush against the flange.
13 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Where can I find the part number?
excellent, thanks for you aportation.
