Zum Hauptinhalt wechseln
  1. 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Disconnect: Schritt 1, Bild 1 von 3 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Disconnect: Schritt 1, Bild 2 von 3 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Disconnect: Schritt 1, Bild 3 von 3
    • Pull on the hood release lever just inside the passenger door to pop the hood.
    • Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
    • Insert the hood prop rod into the hole in the hood marked with an arrow.
  2. 1998-2002 Honda Accord Headlight Bulb Replacement: Schritt 2, Bild 1 von 2 1998-2002 Honda Accord Headlight Bulb Replacement: Schritt 2, Bild 2 von 2
    • Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
    • Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
    • If needed, you can disconnect the air intake (next to the battery) to get some extra wiggle room in order to detach the head light connector on the passenger side. If you remove the air intake, be sure to plug both sides with a clean, lint-free cloth so that nothing gets inside while you work.
  3. 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Bulb: Schritt 3, Bild 1 von 2 1998-2002 Honda Accord Headlight Bulb Replacement, Headlight Bulb: Schritt 3, Bild 2 von 2
    • Turn the head light bulb counterclockwise and pull it straight back to remove it.
Abschluss
26 weitere Nutzer:innen haben diese Anleitung absolviert.
13 Kommentare
I change both bulbs and still high beam don't work what else can be wrong
stankopetek - Antwort
Thanks Barry! It is really saved lot of time. Taking air take plastic tube is the trick. I was able replace passenger side head light bulb. Thanks
gc - Antwort
This site has helped me soooo very much!! I can't thank you enough!!!!
Tina - Antwort
Nobody can replace the headlight for my 1999 Honda Accord (low beam). Everyone says the 9006 is supposed to fit the socket. The socket is fine; the connector for the new bulb is covered by a plastic sheath, which the old bulb doesn't have. Should I go to a dealer for this part?
Art Brymer - Antwort
Did you end up with a solution I'm having a similar issue
Samantha Rivera -
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 61
Letzten 30 Tage: 285
Insgesamt: 159,245
