Zum Hauptinhalt wechseln
1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Tail Light Bulb Assemblies: Schritt 1, Bild 1 von 2 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Tail Light Bulb Assemblies: Schritt 1, Bild 2 von 2
    • Open the trunk using your key in the trunk key slot or by using the lever under the driver's console.
  2. 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Panel Tail Lights: Schritt 2, Bild 1 von 3 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Panel Tail Lights: Schritt 2, Bild 2 von 3 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Panel Tail Lights: Schritt 2, Bild 3 von 3
    • Remove the small plastic screw along the vertical edge of the trunk entrance using a flathead screwdriver.
    • Carefully peel back the trunk liner from around the edge of trunk opening by the light.
    • Locate the two panel tail light connectors located between the liner and the panel tail light assembly.
  3. 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement: Schritt 3, Bild 1 von 3 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement: Schritt 3, Bild 2 von 3 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement: Schritt 3, Bild 3 von 3
    • Grab a light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  4. 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Trunk Lid Tail Lights: Schritt 4, Bild 1 von 3 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Trunk Lid Tail Lights: Schritt 4, Bild 2 von 3 1998-2002 Honda Accord Tail Light Bulb Assemblies Replacement, Trunk Lid Tail Lights: Schritt 4, Bild 3 von 3
    • Locate the light bulb sockets in the trunk lid, located on the back side of the trunk tail lights.
    • Turn the light bulb sockets counterclockwise and remove them from their holes.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 715
