Zum Hauptinhalt wechseln
1998-2001 Nissan Altima Battery Replacement
Was du brauchst
  1. 1998-2001 Nissan Altima Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Open the hood of the car by pulling the lever until you hear the hood pop open.
    • Wear protective gloves when dealing with a car battery to protect against potential battery acid.
  2. 1998-2001 Nissan Altima Battery Replacement: Schritt 2, Bild 1 von 1
    • With the hood now open, identify the battery and the part number.
    • When replacing the battery, make sure that the new battery and old battery have the same part number to avoid issues.
  3. 1998-2001 Nissan Altima Battery Replacement: Schritt 3, Bild 1 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 3, Bild 2 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a torque wrench with a 9 mm attachment to unscrew the negative clamp and remove it from the terminal. Do the same with the positive terminal.
    • Make sure that no metal pieces touch the terminals at the same time, and that the clamps don't touch each other.
  4. 1998-2001 Nissan Altima Battery Replacement: Schritt 4, Bild 1 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 4, Bild 2 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 4, Bild 3 von 3
    • If the terminals are corroded, take the corrosion brush and insert the terminal into it and turn until the corrosion is gone.
    • If there is no corrosion, go to the next step.
  5. 1998-2001 Nissan Altima Battery Replacement: Schritt 5, Bild 1 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 5, Bild 2 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 5, Bild 3 von 3
    • Remove the battery from the base.
    • Be careful as the battery is heavy. To prevent leakage of battery acid, never turn it upside down.
    • Wipe down the base and clamps with a damp rag to remove any dirt or dust that might be present.
  6. 1998-2001 Nissan Altima Battery Replacement: Schritt 6, Bild 1 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 6, Bild 2 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 6, Bild 3 von 3
    • Dry the base and clamps fully with a dry rag.
    • The clamps must be fully dry.
    • Place the new battery into the base, making sure that the bracket on the bottom is in place.
  7. 1998-2001 Nissan Altima Battery Replacement: Schritt 7, Bild 1 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 7, Bild 2 von 3 1998-2001 Nissan Altima Battery Replacement: Schritt 7, Bild 3 von 3
    • To prevent corrosion, you can place dielectric grease or petroleum jelly on the terminal before placing the clamps, but it isn't necessary.
    • Place the clamps onto the terminal.
    • Screw the negative clamp on first.
    • Don't screw it on too tight.
    • Repeat this step with the positive clamp.
  8. 1998-2001 Nissan Altima Battery Replacement: Schritt 8, Bild 1 von 1
    • Remove all tools from the battery.
    • Make sure to keep track of the time your battery has been in your car. They should be replaced every 3-4 years.
    • Do not throw away old batteries. They can be taken to most automotive shops to be discarded safely and appropriately.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Loreye
181 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-9, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 2-9, Briggs Fall 2022
CSULA-BRIGGS-F22S2G9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 403
