Einleitung
This guide will allow the reader to perform the necessary steps in order to access and replace the door window motor.
Was du brauchst
Grasp the panel in with your dominant hand and squeeze while pulling away from the door until the panel releases.
Grasp the door trim panel and squeeze while pulling away from the door until the panel releases.
Grasp the window button housing and squeeze while lifting up and away from the door.
Holding the window button housing, press against the tabs while pulling the plug-in away from the housing. Repeat this for all four control buttons.
Using a 5/16 nut driver, unscrew the door handle by accessing the bolt inside the door panel.
Using a flat head screwdriver, pry off the plastic snap holding the door panel to the door.
Grab the door panel firmly and lift up and away from the door to release the panel from the door.
Drill a 5/8 inch hole to access the bolts behind to release the panel and access the windshield motor behind.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Many ford window motors have replaceable plastic gearsets. These are sacrificial and consist of a plastic gear and 3 plastic rollers. Remove the cover over the gear and pull it out, clean it well. Replace with the new parts and grease and reassemble. The kit is a Dorman part and runs about $20
Thanks a bunch, pulled the motor and figured out the window was stuck. I just had to loosen the window in the track, reinstall the motor and all is well with the world. No money spent, YAY.
