Zum Hauptinhalt wechseln
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
Was du brauchst
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: Schritt 1, Bild 1 von 1
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 2, Bild 1 von 1
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 3, Bild 1 von 1
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: Schritt 4, Bild 1 von 1
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 5, Bild 1 von 1
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 6, Bild 1 von 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 6, Bild 2 von 2
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 7, Bild 1 von 1
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: Schritt 8, Bild 1 von 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: Schritt 8, Bild 2 von 2
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 9, Bild 1 von 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 9, Bild 2 von 2
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 10, Bild 1 von 1
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 11, Bild 1 von 2 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: Schritt 11, Bild 2 von 2
    • Gently unplug and lift out the automatic transmission control unit.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Newsom
39.500 Reputation
67 Anleitungen geschrieben
5 Kommentare
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Antwort
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Antwort
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Antwort
thank you very much .
emad_szs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 27
Letzte 30 Tage: 139
Insgesamt: 43,687
