Was du brauchst
Use a flathead screwdriver to remove the cap from the windshield wiper.
Use a socket wrench to release the passenger-side windshield wiper locking nut.
Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
10 weitere Personen haben diese Anleitung absolviert.
5 Kommentare zur Anleitung
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
does it need to be programmed mine needs replacement my gears are not shifting
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
