Zum Hauptinhalt wechseln
1999 - 2003 Acura TL Ignition Coil Replacement
Was du brauchst
  1. 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: Schritt 1, Bild 1 von 2 1999 - 2003 Acura TL Ignition Coil Replacement, Ignition Coil: Schritt 1, Bild 2 von 2
    • Open the driver side door of car.
  2. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 2, Bild 1 von 2 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 2, Bild 2 von 2
    • Pull the hood latch below the steering wheel and near the door frame towards you to pop open the hood.
  3. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 3, Bild 1 von 2 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 3, Bild 2 von 2
    • Lift the hood slightly to where your fingers can fit under the hood.
    • Reach your fingers under the hood to find the latch that is slightly right off the center.
    • Pull and hold the latch up while simultaneously lifting the hood all the way up until it stays stationary.
    • Be careful that the hood is lifted properly to avoid an accident.
  4. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 4, Bild 1 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 4, Bild 2 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 4, Bild 3 von 3
    • Use a flathead screwdriver to remove one screw from each corner of the cover.
  5. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 5, Bild 1 von 1
    • Pull the engine cover towards you to remove it.
  6. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 6, Bild 1 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 6, Bild 2 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 6, Bild 3 von 3
    • Pinch the socket, attached to engine coil, and pull up to release.
    • With an Allen key, loosen the screw holding the coil by turning counterclockwise.
    • Make sure to avoid exposed wires.
  7. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 7, Bild 1 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 7, Bild 2 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 7, Bild 3 von 3
    • Pull out the old coil.
    • Avoid exposed wires.
  8. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 8, Bild 1 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 8, Bild 2 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 8, Bild 3 von 3
    • Insert the new coil.
  9. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 9, Bild 1 von 2 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 9, Bild 2 von 2
    • Attach the wire socket to the new coil until you hear a "click," indicating that it is properly inserted.
  10. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 10, Bild 1 von 1
    • With an Allen key, tighten the screw into the new coil turning clockwise to secure into place.
  11. 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 11, Bild 1 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 11, Bild 2 von 3 1999 - 2003 Acura TL Ignition Coil Replacement: Schritt 11, Bild 3 von 3
    • Reattach the engine cover and secure the screws with the flathead screwdriver.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 165
