Einleitung
This is a step-by-step guide will show you how to replace the ignition coil of your 1999 - 2003 Acura TL. Though this is a guide to replace a single coil, it is highly recommended that all of the ignition coils are replaced once or the engine may start to misfire. By following this guide you can save yourself an expensive trip to the mechanic.
Before you begin, turn off the car and put it in park. If you have driven recently, wait for the engine to cool before starting the repair.
Was du brauchst
Pull the hood latch below the steering wheel and near the door frame towards you to pop open the hood.
Lift the hood slightly to where your fingers can fit under the hood.
Reach your fingers under the hood to find the latch that is slightly right off the center.
Pull and hold the latch up while simultaneously lifting the hood all the way up until it stays stationary.
Pinch the socket, attached to engine coil, and pull up to release.
With an Allen key, loosen the screw holding the coil by turning counterclockwise.
Attach the wire socket to the new coil until you hear a "click," indicating that it is properly inserted.
With an Allen key, tighten the screw into the new coil turning clockwise to secure into place.
Reattach the engine cover and secure the screws with the flathead screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
