Einleitung
As Miatas get older, some parts start to wear out. This includes the car's audio system. If your audio makes a rattling or vibrating sound, it may be time to replace the speakers.
This guide will show how to remove the door speaker on a 1999-2001 Mazda Miata, so that it can be replaced or upgraded.
Step 1 is optional but is generally good practice when working with the electrical system.
Before starting, it is recommended that you get replacement retainer clips. They break easily. Be sure to power down the ignition, place the car in park, and engage the parking brake.
Was du brauchst
Remove the cover around the door latch by pulling the handle and rotating the cover.
Detach the connector that powers the speaker by pressing down on the top latch and gently pulling.
