Zum Hauptinhalt wechseln
1999 Buick Century Window Regulator and Motor Replacement
Was du brauchst
  1. 1999 Buick Century Window Regulator and Motor Replacement, Lower Window: Schritt 1, Bild 1 von 1
    • Lower window to about ¾ of the way down or until the frame that the window sits on is visible in the lower opening.
  2. 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel: Schritt 2, Bild 1 von 3 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel: Schritt 2, Bild 2 von 3 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel: Schritt 2, Bild 3 von 3
    • Locate the 3 screws in the door.
    • 1 screw is in the door latch (phillips head)
    • The other 2 are in the door tray (10mm socket)
  3. 1999 Buick Century Window Regulator and Motor Replacement, Disassemble Door Panel (cont'd): Schritt 3, Bild 1 von 1
    • Pry away the door (a flat head can be used as seen in the image, but any wedge like object would work.)
  4. 1999 Buick Century Window Regulator and Motor Replacement, Disconnect Necessary Cables: Schritt 4, Bild 1 von 2 1999 Buick Century Window Regulator and Motor Replacement, Disconnect Necessary Cables: Schritt 4, Bild 2 von 2
    • Tweeter Connection (circled in red)
    • Disconnect the tweeter connection where the red arrow is pointing.
    • Automatic Lock Connection (circled in green)
    • Disconnect the automatic lock connection from its location in the green circle.
  5. 1999 Buick Century Window Regulator and Motor Replacement, (Remove Plastic If Applicable): Schritt 5, Bild 1 von 2 1999 Buick Century Window Regulator and Motor Replacement, (Remove Plastic If Applicable): Schritt 5, Bild 2 von 2
    • If the internal door panel is covered with protective plastic, remove it before proceeding.
  6. 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor: Schritt 6, Bild 1 von 3 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor: Schritt 6, Bild 2 von 3 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor: Schritt 6, Bild 3 von 3
    • Locate and remove the 3 screws holding the window motor in place (Wrench and 10mm socket needed).
    • Disconnect the window motor connection wiring.
    • Wedge in-between the outer shell of the door and the window to hold the window in place (be careful not to damage the window. May have to stick it in at an angle).
  7. 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor (cont'd): Schritt 7, Bild 1 von 3 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor (cont'd): Schritt 7, Bild 2 von 3 1999 Buick Century Window Regulator and Motor Replacement, Removing The Window Motor (cont'd): Schritt 7, Bild 3 von 3
    • Locate and Remove the four 10mm screws below the interior door latch.
    • Locate and remove the two 10mm screws on the window frame.
    • Remove the motor and the regulator through the hole.
  8. 1999 Buick Century Window Regulator and Motor Replacement, Replace The Motor And The Regulator (Reassembly): Schritt 8, Bild 1 von 2 1999 Buick Century Window Regulator and Motor Replacement, Replace The Motor And The Regulator (Reassembly): Schritt 8, Bild 2 von 2
    • Follow steps in reverse order to connect the new window motor and regulator and to reassemble the door panel.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 4,673
