Zum Hauptinhalt wechseln
1999 GMC Suburban Brake Light Replacement
Was du brauchst
    1. 1999 GMC Suburban Brake Light Replacement, Brake Light: Schritt 1, Bild 1 von 3 1999 GMC Suburban Brake Light Replacement, Brake Light: Schritt 1, Bild 2 von 3 1999 GMC Suburban Brake Light Replacement, Brake Light: Schritt 1, Bild 3 von 3
      • Before you begin, turn off your car, put it in park, and engage the emergency brake.
      • Select the side of the car you would like to work on first.
      • Open the trunk doors.
      Frag FixBot
      Kommentar hinzufügen
    2. 1999 GMC Suburban Brake Light Replacement: Schritt 2, Bild 1 von 3 1999 GMC Suburban Brake Light Replacement: Schritt 2, Bild 2 von 3 1999 GMC Suburban Brake Light Replacement: Schritt 2, Bild 3 von 3
      • These two holes have screws inside of them, so unscrew them to get the brake light out.
      • The screws that will be removed for this step are "Round washer head pozi-drive tapping screw tail lamp assembly M4.2-1.41 x 20mm".
      Frag FixBot
    3. 1999 GMC Suburban Brake Light Replacement: Schritt 3, Bild 1 von 3 1999 GMC Suburban Brake Light Replacement: Schritt 3, Bild 2 von 3 1999 GMC Suburban Brake Light Replacement: Schritt 3, Bild 3 von 3
      • When removing the tail light there are little hooks with holes that are used to hold them in place as shown in the first photo.
      • The tail should already be loose from the previous step so pull it out slowly by turning it on its side and then pulling forward.
      • Use the 7 mm socket to unscrew the two bolts securing the brake light housing to the tail light assembly.
      • The screws in this step are "Rexka 30pcs M4.2-1.41 x 20mm".
      Frag FixBot
    4. 1999 GMC Suburban Brake Light Replacement: Schritt 4, Bild 1 von 2 1999 GMC Suburban Brake Light Replacement: Schritt 4, Bild 2 von 2
      • After taking off the screws, take the brake lights out and find which light isn't working by stepping on the brake.
      Frag FixBot
    5. 1999 GMC Suburban Brake Light Replacement: Schritt 5, Bild 1 von 1
      • With the actual light, unplug them by pulling them out but not with too much force.
      • Plug the new light bulb(s) in place of the ones that don't work.
      • Please be careful with how you remove the bulbs because they are made of glass.
      Frag FixBot
    6. 1999 GMC Suburban Brake Light Replacement: Schritt 6, Bild 1 von 2 1999 GMC Suburban Brake Light Replacement: Schritt 6, Bild 2 von 2
      • Now put everything back together and put all the screws back on.
      • The steps are the same on both sides and is a fairly simple and fast process.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
CSU Los Angeles, Team 12-10, Ribeiro Fall 2023 Mitglied von CSU Los Angeles, Team 12-10, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G10
1 Mitglied
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 1,022
